59 bhp is more than enough
Banned
i need a rough dia of the 1.6 sunny discs. basically i need to find out if they wil fit with my 13 inch alloys on.
Titch said:99.9% its 15's
mike said:Sorry titch but gtir calipers will fit behind 14" steels or alloys as the Gtir has 14" alloys as oem. The ga16 calipers mike's getting will just fit behind 13" steels as craig has done it before
Yes, u could get ABS on a Micra and they had rear disks; I think ABS disagrees with drum brakes or somet' like that. Usually if a normal car has disks all the way around it's got ABS.DoomPixie said:i seem to remember being told that some K11's had rear disks ( think it was the ones with ABS) so surley a rear disk conversion wouldnt be that hard, probably just a case of swapping the rear axle (if you can find one with rear disks) and makeing up some pipes for it and handbrake cables, saying that the ones from a micra with ABS might work. but yeh, i have never actually seen a K11 with rear disks in the scrappies round here so i dont know how true that is.
Owen
