Hello, new here and first time poster, hoping this is the right area to post in. ?
So a few weeks back my GF acquired a (LeftHandDrive) K11 (2000 mod I think) and it had a powerthief that turned out to be the cassette player. It was tossed and I got a newer CD player that I fitted in. Little did I know that what I thought to be ground cable in the harness turned out to be the "dimmer" cable from the light switch. It worked fine, until it did not and burned the plastic off of the cable. ?♂️ Lesson learned now, always double check and check again. Removed the radio and made sure there was no connection between chassis and plus side.
However, neither dash lights, park lights, plate lights or back lights works. Brake lights and haz/blinkers works fine.
I found a burned red with blue cable that came from the "CONT-ASS'Y D.T.R.L" box (see the picture for what connector it came out of) and I wonder if this is the cable I need to mend together again (I snipped it away since it was burned). I could use some help/ideas what I need to do to get it working again and safe (don't want to have a burned/stripped cable possibly hitting ground). I have checked the fuses and only removed the "radio" fuse, all the others are fine.
I fear I have to remove the dash plastics to get all the fried red with blue cable, but if I get some pointers on what screws to remove that would also be nice
Best, Bjørn
Best, Bjørn
