You will need to wrap the hose in tape and then either use a very fine hacksaw blade or a dremel type cut-off tool. Stainless braid is very sharp, so wear thick gloves.
I find that cable cutters (the large ones where the blade overlaps, not snips where they just meet) are ok for cutting the small stuff. Bigger stuff cuts quite well in a chop saw if you tape it and ram the saw down as quickly as possible.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
