Curtis' micra k10
curtis
curtis
Ok guys update
Got the head back on etc see pics
Started it up today and it ran :D (Y)
Just got some fine tweeking to do
nexussteve
The reason you're happy!
There's a vid on YouTube of some guys revving a K10 in a scrappy until the engine blows up!
It's surprising how long it lasts!!
Keep it going dude!! Don't let us down! :D
curtis
curtis
"Running in" seems to be going ok
Bike carbs are slightly slower then the webers, but not by much
At 130miles so far :)
frank
nice one curtis :cool: , you could do with a wideband lambda sensor and voltmeter on the dash, to finetune those carbs, eh
curtis
curtis
Not sure what that set up would allow me to see...could you explain a bit more Frank :)
They aren't good at low revs for power, but hey thats the whole point of dropping down a gear ;) lol
frank
curtis
mine is just a narrowband setup, so it only gives a small window of air/fuel ratio (about 14.2:1 to 15.2:1 apparently) but it,s still usefull (albeit limited).
i think the 2 outer wires on the sensor are for 12 volts in, and pre-heater, and the middle wire outputs a voltage of 0 to 1v, (0.5v being 14.7:1 mixture).
a wideband sensor has a much wider range, but i think they,re a few bob tho o_O
curtis
curtis
Wouldnt this mean putting a hole in my exhaust mani? dont think i wanna be doing that lol
Im quite happy with how they are atm its just trying to set-up the timing and idle! also the acc cable doesnt sit properly!!
superls
K10 Tuner
curtis
i have a 4 wire sensor, but dint know the wiring, i think it has 3 white wires and 1 black, what wires does yours have?
frank
curtis
you only have to screw the threaded insert out of a cg manifold, then weld it into your downpipe.
are the carbs variable venturi (with a rubber diaphram/dashpot thingy) ?
superls
mine,s 2 white,s and the middle black signal wire, i think the 4th white is an extra earth
frank
Im pretty sure they are yes, as you can't turn them upside down with fuel in them otherwise the diaphram swells
i think the vv carbs are designed so that when you hit the throttle, the butterfly is wide open but the slide is delayed, which creates a high vacuum around the jet, adding extra fuel (acceleration enrichment).
so if yours has a flatspot when you floor it (if thats what you were saying), the slides might be lifting too early (maybe too soft springs or too much vacuum acting on the diaphram) ?
curtis
curtis
oo i'll have to have a play about with them..
Its basically a flatspot at low revs, but soon as its picked up the acceleration is really good, if not better then the webers
the webers were good for the whole rev range
frank
curtis
dont forget those carbs were setup for a bike, with a lot less rotating mass, where the rev,s were climbing at a much higher rate (you could do with a super light flywheel really :cool: )
if that cam is a reprofile, it might need advancing ? ,it might bring the powerband down a bit, so you dont need to rag it all the time :p
superls
K10 Tuner
exacty what mine did, if you flattened the throttle at say 2.5k not alot happened, actually it worked better if you didnt go the full way dowm, but when you reach 4k it took off then it was change gear time, same in a ll 4 gears i had at the time, lol
curtis
curtis
Yep, pretty much it, nothing really happens at 2.5-3K but soon as 4k comes along its power all the way...lol
I do miss the webers now :(
But if i get the timing sorted and the idle etc done it should be ok
frank
Nope...but im looking into getting one...
FFS, no wonder you,ve got no response till 4000 o_O .
i usually put some 2" masking tape over the bellmouth,s, then punch a 20mm hole in the middle (you should get instant throttle response then), then gradually open the holes up, to give some idea of jet size, needle setting, filter size and diaphram spring etc
curtis
curtis
lol ok i'll get somthing to do that, ill try the masking tape thing first and see how it responds :) Cheers Frank (Y)
superls
K10 Tuner
lol calm down frank, i didnt have one either buts that cos i couldnt fit one in, my next set will have one tho, but will try the masking tape method also.
curtis
curtis
I lost my rassp...:( Think it went with the webers lol
So it was the carb set-up that created the rassp in the exhaust? How does that work?
Speedle
told you so! didnt listen :p
powerband with the bike carbs is totally different to the webbers. i.e. sh*t!!!
the manifold design for the webbers was much better and infact the webbers were better in everyway as far as im concerned. some may not agree but unless youve tried both im not interested in your opinions :D
curtis
curtis
pfft you should have sold family members of limbs in order to keep those webbers! you'll likely never see another set again now. dedication to the cause my friend!
*or limbs!
Daveeeee wont be keeping them long, and i have first dibs on them ;)
curtis
curtis
Dont think anyone would want my liver lol
errmmm Kidney?
Nah it should be fine, soon as i get my coilovers as well ;)
daveeeeee
Beeing someone who has also now tried both the webers and bike carbs,, i agree with speedle, the webers are better, but they havent blown me away in comparison. pound for pound the bike carbs are prob better value, and if set up right, i think they could easily give the webers a run for there money.
frank
curtis
"calm down frank" lol :D .
bear in mind the mainjet realy only governs the mixture at full throttle (or in the case of vv carb,s, slide fully up), and the tapered needle does most of the metering at smaller openings.
for example, the su carb,s (same vv setup) had only 1 mainjet size and hundred,s of different needle shapes.
and there,s no reason why the carb,s should,nt be at least as good as the webber,s, the carb,s and manifold have a short, straight inlet tract like any superbike or motorsport engine, perseverance will pay ;)
Speedle
indeed i agree with you there dave, the webbers dont give alot more HP but they have a better power delivery and power curve IMO plus they are easier to tune and live with day to day :)
about time we had some updated pics of your project dave! :D
Ceirwan
If it makes you feel better my standard carbs have a flatspot when i floor it, but without the added benefit of loads of power once its through! :)
superls
K10 Tuner
not having tried the webbers i cant base my opinion on complete fact, but i never found my bike carbs hard to live with day to day.
ok the maunal choke was a bit of a pain after the standard auto, but the webbers have this also?
same with the idle up thing.
and with a 50-50 driving style i could still return between 35-37 mpg, (dont know wot the webbers do??
curtis
curtis
I havent even hooked the manual choke up on the bike carbs yet, and its ran really good from cold, considering how cold its been!!
They arent as good on fuel as the webers imo
daveeeeee
i never had to use the manual chock on them carbs and never had problems starting them, might be a different story tho when we hit january! as for mpg i cant accuratly say yet as the webers where jetted and tuned to curtis's ma12, i wont get a true picture of mpg untill their tuned to my engine and had some more use. but theres no way there worse than the bike carbs. 35mpg is prob the max on the bike carbs.
curtis
curtis
Yeah, sometimes it starts on the first turn, and sometimes you need a little throttle...but thats usually once they have been running for a while
I still need to get my locking wheel nuts off without the key, so gonna have another look tonight
curtis
curtis
I didnt sell it with the white alloys on
K10Franny is really loving the car lol, he wouldnt stop smiling :)
im glad he likes it so much and hes already planning a re-spray...
£900 was the price
GTI will be picked up Friday
Well chuffed with www.elephant.co.uk
Im insured on the almera GTI 2.0 1999 For £760 TPFT im 19 with 1 years no claims :D
curtis
curtis
Getting my Red K10 MOT'd today :)
I must say after about a year and a half of driving my modded k10 and the almera, i hate the standard micra k10s suspension!! lol
nismo
mate im lovin my new lower stiffer k10,its like another car,my wheels go off to be refurbed (black steelies)next week then my brand new yokahama adrives go on! IM LOVIN IT!
curtis
curtis
Yes i agree, i would now recommend anyone with a standard k10 to get uprated shocks and lowering springs...Does improve it a whole lot!!
curtis
curtis
Anyone heard or seen any pics updates on my old white micra? K10franny is the members name who bought it from me..
That car had one amazing engine in it and would be a shame to waste it...i want it back lol :)
