compression reading
S
sukoo
can i just check with u guys here
wat the compression reading for cg10 n cg13?
is it the higher the reading the pickup will be faster?
how about low compression reading?
thank
It sdhould be 9.5:1 for both IIRC, higher comp is better for NA, lower for forced induction, you will see very little variation without having to do quite major work to increase the compression
ok thank
hmmm
if let say i tc a 1.0 or 1.3
compression should reduced to how much huh?
anyone didi tis conversion b4?
any idea of how to setup the tis tc package?
Do you mean compression ratio or do you mean compression test?
Ed
Ed
sori
i talking abt compression reading when testing on a na engine and tc engine
Craig said:
I think he is talking about comp ratios for turbocharging
cos i got frez getting a 1.3 engine
but then the engine come wif a 1.3 turbo lsd gearbox
so he was wondering if tat engine was a tc engine last time
sori if i cant explaint it earlier
