Coilpack Flyweel VS DizzyFlywheel
Hi Guys,
Is the dizzy flywheel compatible with the coilpack gearbox / starter motor setup?
As in is the offset of the ring gear the same across both flywheels? I dont have any to hand to check & do not need the crank sensor ring of a coilpack flywheel as the trigger wheel inputs taken from the front crank pulley.
Any info / advise is appreciated.
No, they're totally different Paul. Images courtesy of TTV :)
