Clutch problem
Hi , fitted a new clutch kit and everything seemed fine and all went well until we tried it and the pedal just goes to the floor with a tip of the foot and has to be lifted back up. Please tell me it's something daft we've missed or is this the case of the box coming off again
Sent from my MYA-L11 using Micra Sports Club mobile app
Have you got the cable clipped in all the mounting points?
The only other thing i can think of if it's not that is that the release bearing hasn't been fitted properly, because the clutch is cable operated they're pretty simple and there's not a lot else it could be.
OP
OP
Aubreygil
Hi , got sorted everything was as should be. Cable seemed to be the problem weren't getting enough adjustment on it but fitted a washer and reversed the locking nut to the front and adjusted from there. Worked we got clutch, thanks for the responses
