Clutch Problem??
rlees85
When I press the clutch in (or release out) it feels a little like its rubbing against something and makes a sound to match...
Seems to be coming from the bell housing.
Tried putting a load of spray lubricant (not WD40) around where the clutch arm goes onto the bell housing and it has made a little improvement... but not fixed it.
Anyone got any ideas??
i got this, lubed the same place (but with oil) and it went, cant tell you how long it took because one day i just realised that it wasnt there anymore:)
ive got a noise from my clutch tooo, and its really *****ing me off now, its like a creeking noise, think it might be the spring, but i used a whole of WD40 to get rid of it and its still there
Seems odd tho, after i been driving for a while (about 30 mins) it seems to fade away:S
Sounds like your release bearing, mine is really noisy
I don't think it matters, it's just where you're a bit heavy on the clutch. I'll fix it when I change my clutch, only 10,000 miles to go lol
any ideas how to get rid of it easly? i do over 80 miles a day ( to drive to uni ) and its really ***ing me off
probably going to be a case of removing the bell housing from the engine.. so not easily no.
not unless grease does it, which you have already tried :(
I'm experiencing the same problem. Can I just spray WD-40 around/in where the clutch arm goes onto the bell housing without causing any problems?
