car won't start
It's a w reg celebration.(47000 miles)
we have good sparks. the plugs appear dry after prolonged starter use. there is fuel flow to and from fuel rail.(albeit not very high pressure).
Anyone know how to check injectors / fuel pump.?
Thanks.
frank
w reg is when they changed to coil over plug iirc ken, is yours coilpack or distributor type ?
Stani1029
Try pulling out the fuel pump fuse then turn it over for a couple minutes then plug it back in see if it starts
solarice
If its really flooded might even start and run for 4 seconds or so before cutting out. :D
You should hear the fuel pump running / priming when you turn the ignition on.
Ed
Fusion Motorsport
MSC Founder
Official MSC Trader
Are there any flashing lights on the dash?
Have you checked the plugs to see if there is any fuel on them? If they are dry try pouring a tablespoon of fuel down the throttlbody inlet and see if it does anything then. If it does chances are your ECU has immobilised the car and will need reprogramming/replacing.
