You should be able to wire an alarm kit in without one too! No doubt it connects to the door switches in some way, positive & earth. The alarm should have instructions too
The alarm has sort of instructions. My K10 doesn't appear to have door pins. The alarm instructions are saying I need to wire to the feed point to the interior lights the K10 I've got has interior lights, however there isn't any power going to them which is why a wire diagram would be helpful.
I know it's in the haynes, I'm unable to obtain one till late this week.
Every K10 has them. They're black rubber things. Remove the rear door cards and you'l see the wiring for them in there. Also visible when you open the doors
Hi K - I need a schematic / wiring diagram for the fuel & engine temp sensors / instrument panel, if you've got one.
PS: - My 1988 1.0L K10 Micra fuel guage always reads low (1/4 tank) even for a full tank. Although directly 'stimulating' the guage with+12v makes it rise slowly to the top/full position,... as it charges the 0.22uF capacitor on the rear of the instrument panel.
- Is there an easy way to get to the (tank) SENDER unit to check it out, without draining & pulling the tank ???
Joe
