Can I remove the first cat?
Hi,
As some of you know my first cat is total empty.
And whatever I did, due to some angle, i cant fit the exhaust pipe correctly to the below of cat. So there is always a leak. Car shutters...
Is there a decat pipe for replacing the first cat?
So that i can maybe fit correctly.
Thanks in advance
Of it's leaking it's the joint between the cat and exhaust, there are some ways of sealing it again
Enviado do meu MI 8 através do Tapatalk
I had same thing with the down pipe and catalytic converter. The gasket won't fit on right I have sanded back the flange as much as possible only getting a slight fitment but its held and not blowing.
So I got a new gasket to fit next time I remove its been alright so far and I don't think it is blowing but it could have fit a lot better.
The new gasket looks different maybe if I tap it on it might have fit better.
To me it was something about the angle or that the down pipe pulled back ever so slightly.
And being on own its awkward to bolt up and hold in place at same time to begin with.
Only difference being to my knowledge the cat is functioning and has not been emptied.
Sent from my ASUS_T00P using Micra Sports Club mobile app
