Can I fit coil 1L gearbox on my Dizzy 1.3 engine?
I don't think so, the PnP option is the 1.0 Gearbox from the restyling cars with dizzy engines, I think that is from '98 to '00. It has to have the starter motor on the top and 18 teeth on the shaft. Also, the speed sensor is electronic and you have to use your own.
As far as I remember it was quite common except on the very early 1 litre boxes which didnt bolt up. If you search on here youll probably find old posts detailing it
