Camshaft timing?
So can someone please check whether these cams are correctly timed?
This is at TDC. The crank pointer is pointing at the second notch from the left on the crank pulley.
I have got very mixed reviews. Some one said the exhaust cam is advanced. Someone said the chain is completely in the wrong position. Had a few say it is correctly timed. By Frank's method, the cams are at 10 o clock and 2 o clock, seem okay to me?
that slack is normal ihtisham, the top tensioner is a combined manual and hydraulic type
the lower one is hydraulic only
right thanks Frank! honestly the facebook comments have me so worked up on the amount of 'problems' my car has.
thanks for confirming that slack is normal. :)
