Does anyone have cg10 and cg13 cam lift measurements? cheers
F fuzzy-hair-man Nov 25, 2017 #2 Afaik CG10DE: inlet lift 5.59 exhaust lift 5.59 CG13DE: inlet lift 7.46 exhaust lift 7.945
R Roger169 Nov 26, 2017 #3 I've got a set of cams out of a 1400....would they be to much for a 1000cc ?
frank Club Member Nov 26, 2017 #4 Roger169 said: I've got a set of cams out of a 1400....would they be to much for a 1000cc ? Click to expand... no, they are very tame
R Roger169 Nov 26, 2017 #5 frank said: no, they are very tame Click to expand... What would be better the 1300 or 1400.... Cams need to be standard so getting them reprofiled is out of the question
frank Club Member Nov 26, 2017 #6 Roger169 said: What would be better the 1300 or 1400.... Cams need to be standard so getting them reprofiled is out of the question Click to expand... cube alpha inlet if you can find one, and 1.3 exhaust
R Roger169 Nov 26, 2017 #7 frank said: cube alpha inlet if you can find one, and 1.3 exhaust Click to expand... What's a cube alpha?
frank Club Member Nov 26, 2017 #8 http://www.automobile-catalog.com/curve/2001/2201690/nissan_cube_x-alpha.html
R Roger169 Nov 26, 2017 #9 frank said: http://www.automobile-catalog.com/curve/2001/2201690/nissan_cube_x-alpha.html Click to expand... Easier finding hens teeth unless you know where there is some
