Bumpstops
solarice
Right the cars being lowered just wondering whether or not to uprate the bumpstops, while im at it.
Ive read when lowering you should cut the current bumpstops by the amount your lowering, in this case 35mm.
So does anyone know if the current ones can handle being shortened or is it more worth my while to buy newer shorter ones, from powerflex for example.
Cheers in Advance.
Kris.
cheers for help
Ive decided for now to run the standard ones, if anything happens and they cant seem to handle it, will change them then.
yeah shocks have been changed also. Finished putting them on along with the whiteline gear i had yesterday evening. Everything seems fine so far :)
