superls
K10 Tuner
hi all,
for those of you that may be interested, ive had my diy bike carbs on the car for over a week now, and i must say that they add a boat load of power, i can do in third now what i would have had to do in second before, if that makes sense, the same with 4th etc.
it accelerates and pulles loads better and faster, just for instance, on the private road down to work (it is actually a private road) before i could only attain 80-85mph, now i can go off the clock,
however i really need to get them set up correctly as i have only balanced them with my vacuum gauge, i need to get the fueling sorted out, but dont have the £150 ish ive been quoted.
the only downside at the moment is they are heavier on fuel than the standard carb, understandably, lol.
no pics of them on the engine unfortunately, the only ones ive got are HERE, but the only difference is that the manifold is now painted black and there are some push fit air connectors on the inlet pipes, to connect the vacuum gauge etc to. ill tru and get some pics later on today.
