i would have thought that the vented calipers were wider personally, but 1 member said last year that they were the same, i asked for pics or measurements but the thread died with no feedback iircWould you need different calipers for those disks then?
I'm thinking I'll just keep the original brakes and get them reconditioned
the member said his were 12mm thick (very narrow for a vented disc !) but no pic tho http://www.micra.org.uk/threads/brake-discs.46164/#post-477883i would have thought that the vented calipers were wider personally, but 1 member said last year that they were the same, i asked for pics or measurements but the thread died with no feedback iirc
Mat Humphries sells the vented oem discs, but states in the catalogue that you have to have larger calipers.
Why not get the 100nx calipers and fit vented discs to that easy fitting!!!!
J
That's what I've got The first set went well for a mile until the nearside seized... As if a 1.0 isn't slow enough already
Yep I'm always on 13'sDo the 100nx's clear on 13 "'s
Go for Almera brakes, that's what I meant not 100nx haha, we were going to get those though!Reckon a change is imminent then
Yah n15 ventedOhhhh.....
1.6 Almera?
Thats what i have fully sandblasted. Painted and rebuilt with new rubber seals... Just waiting for a set of vented discs, braided brake hoses and performance pads... And sorted!!!
I also have a sex of 100nx calipers fully rebuild somewhere in me garage i may need to sell at some point etc!!
J
The first set did one corner and then....
High temp paint didn't last long :/ haha
Oooh daaamn, i used hammerite red, they take heat well and long lasting as ive used it before, highbtemp paints in my opinion are rubbish, theybstart flaking off...
J
is the 100nx and Almera gti simlar spec also is Fitting easy ? And Diffrents ?Why not get the 100nx calipers and fit vented discs to that easy fitting!!!!
J
Are the disc bigger or about same ?100nx brakes and almera brakes are the same fitting
Both 247mm diameterAre the disc bigger or about same ?
just wana fill my gap in the alloys I guess they need 14inch alloysWhy ? my standard brakes are very, very good ?
I run 14" alloys of a mazda, with 5 spoke thick -ish arms, gap is filled not badjust wana fill my gap in the alloys I guess they need 14inch alloys
I like that something like your alloys are goodI run 14" alloys of a mazda, with 5 spoke thick -ish arms, gap is filled not bad
Thanks pm I'll take themThe almera brakes i have are bigger than my Nx100 calipers i have in me garage. There different in sizes from what i can see. But both calipers do need washers to space them central on the discs!!!
Ill have to dig out the NX100 calipers and put em up for sale......
J
what are the stopping power 150 bhp on the Almera ones ? also what types of washers do they need to fitThe almera brakes i have are bigger than my Nx100 calipers i have in me garage. There different in sizes from what i can see. But both calipers do need washers to space them central on the discs!!!
J
So guessing it needs spacing out with washers,Circular washers, with a hole in the middle would be my bet
Came off a MX 5 I believe, had to drill out the centres to fit. Very easy, just use a rotary file on a leccy drill....about an hour and done all four.I like that something like your alloys are good
What are the Almera gti ones 14 or 15 inch I like the 5 spokes tho mx 5 onesCame off a MX 5 I believe, had to drill out the centres to fit. Very easy, just use a rotary file on a leccy drill....about an hour and done all four.
MX5 wheels ftwI run 14" alloys of a mazda, with 5 spoke thick -ish arms, gap is filled not bad
Yeh there the ones I like, are there any for sale which is already drilled to fit mines ? And are they light or heavyMX5 wheels ftw
£41 for four wheels with tyres on, bargain of my life!Yeh there the ones I like, are there any for sale which is already drilled to fit mines ? And are they light or heavy
I like the idea U got and done, well worth keeping mate,£41 for four wheels with tyres on, bargain of my life!
Doubt it, I spent a few hours with a dremel and flap wheel to get them to fit.
MX5 wheels ftw
