best way to shift burred back box nuts !!!
Typical only 2 nuts and they are burred to the point of getting no purchase socket spanner and ring spanner no good what to ever :( was thinking for ease hoping to remove system from cat back and hack saw the blitters off as i cant get decent access or leverage with axle stands ( thats if the cat bolts are able to be removed ) !!! Or is a drill and decent metal drill bit best way to go ? Simply need it off and get the nismo on again all pointers much appreciated ! (ps were soaked in wd40 etc but no good) ;)
Can you fit a small set of these on the nuts?
some of the backbox nuts are captive/welded on iirc, and 2nd cat nuts are usually badly rusted eh, i usually use a grinder if they,re really bad :)
Yep they look captive typical as the Super S werent nice easy job it was ;) looks like ill be cursing the cat bolts and getting some new discs for the angle grinder :mad:
