bellys p11
Belly93
to turbo or new lump :/ hmmm
i was looking through auto trader and found this for £200 went and took a look looked alright so went for it
got it recovered to work today
best get started on this list :) will keep this updated
Belly93
Belly93
Headlight ordered from local motorfactors, should be here tomorrow new drivers sill panel ordered read abs with diagnostics came back as front right speed sensor open/short circuit​
Enuo
Glorified Electrician
Will be a hall effect sensor, unlikely but not impossible its failed, I'd check for broken/loose wiring first. Check for voltage fluctuations when you spin the hub (with disc in place) or pull the sensor away and wave something ferrous like a small bolt in front of it :)
Belly93
Belly93
Ill priice. A sensor if its cheap ill just buy one :) trade discount and what not, thank andy :)
Enuo
Remember that breaks in the wiring can be in the loom not just in the sensor, diagnosis with a multimeter is ALWAYS the best route to take first :)
Belly93
Belly93
new headlight fitted now,
interior shot
drivers seat could do with a repair might see if i can find a replacement
part of the mot failure
looked at it from the outside of the wheel arch and the bit in middle was rotten too so out it came,
i attempted to weld it back in looks **** but it holds so not too bothered lol
bonus piccy
Belly93
Belly93
how does that work for the abs sensor as it only has 2 wires and my multimeter papers say not to test continuity while passing current
Enuo
You're testing voltage. It probably earths through the mounting point so you have only a supply and signal wire...
Only thing REALLY to watch out for is that you don't try measure the voltage in current mode, as you'll short through the meter and cook it :) I've seen a multimeter that was shorted accross a 240v supply. It exploded. The bloke went to hospital with burns...
Belly93
Belly93
1.6? Is it the GA engine ?
Sent from my HTC One using Tapatalk
yeah it is scott,
and cheers andy ill take another look :)
Belly93
Belly93
im not assed painting it in the morning lad :) need to weld a patch on the oustide next
dude what you doing with the mera gti seats?
there going in my micra, but me dad bought another one for himself, ill ask him what hes doin with his in the morning
Nice man, I feel your pain with the rust, it's exactly where mine had gone although a lot worse than yours.
Check around the rear seat belt bolts, as there rotted on mine as well
the inner sill, the sills themselves and the chassis legs would be another place to check as well. I am only showing you photos and giving you pointers as this is what has gone on mine.
BUT - a worthy upgrade to a Micra, once fixed, and you start doing bits to them, it will be a really good car :) and they look really good in silver too. I had a 1.0 k11 white 3dr before this :) Here is a photo of mine (and mine was originally an SRi, so same bumpers and interior as yours :) )
skymera
Brutal Honesty
Would be nicer without that nasty shopping list.
Do you even have anything Apexi, Samco or AEM? :rolleyes:
Apex-i S-AFC II
Apex-i cone filter (Genuine one from driftworks)
Fidanza Flywheel
AEM C-A-I
AEM Bypass valve
Samco hoses on links of CAI, breather pipes too
