Just for curiosity, why are you moving battery to boot?i need to move my battery to the boot what size cable do i need (not what length) i need to know the gauge if anybody can help
Must admit Mika, that was my first thought as well....Just for curiosity, why are you moving battery to boot?
thanks i know how to move it just need to know what gauge wire nissan useGoogle is your friend..........took me about 30 secs to find this.........
Try reading the link right to the end, you will find the information that you need.............thanks i know how to move it just need to know what gauge wire nissan use
If they are good quality, multi stranded copper (NOT aluminium!), with the conductor (less insulation) between 9 and 10mm dia then probably OK, but most jump leads that I have seen, despite quoted amperage spec, are not as described above. Also I suspect that you are going to need in excess of 4 metres to get the correct run from front to back. The cable that I would use (010602) is sold HERE for about £5 a metre...thank you, i take it jump leads that are rated 200amp or ok to be used
Before you commit to buying cable, work out the run that you intend to do, keeping the cable well shielded from potential scrape damage and clear of the exhaust etc, do a temporary, attached run using clothes line or similar, then remove and measure the length. Obviously you are only going to have route the positive cable as the negative can be an earth point local to the repositioned battery.you are a gent
Had assumed that you were putting it in the boot. If inside the car then to comply with any track/scrutineering requirements I would think that you would need toyeah cheers the battery is going where the back seat is ie behind the passenger bolted down ,thanks for your help
