esha
OK, ive just installed a new sub and amp in the motor and am having a little bit of a problem!
Firstly I just rigged up the sub (FLI 1000w active sub) without the amp or 6x9's, everything fine with thumping bass, groovy!
Now, Ive rigged up the amp (Mutant 2channel 1000w i think!) and everything else, used a proper junction box to split the power from battery to amp and sub etc etc, but now when i turn everything off I get a thump/pop from the sub.
No matter how I turn everything off, turn HU down then off then switch ignition off, I still get the pop and i dont think its doing the sub any favours! All the leads are connected as they should be, BUT, in my haste ive left everything a bit messy, could it be a simple case of the wires are to close together and is causing interference or am i barking up the wrong tree? My bro had a thought that it could be power surge and i should try using a slave battery, which is obviously completely impracticle!
Any ideas would be greatly received as at the moment im thinking of disconnecting the sub before I turn the ignition off!
