Back to the turbo days!
Hi guys!My name is Nik i'm 24 years of age and currently living in Greece..As the title say's i used to own a small turbo pocket-rocket(Daihatsu charade Gtti) due to some difficulties i had to give away(totalled) and moved on buying a suzuki ignis sport..Was happy with the Iggy but due to financial probs(got fired and stayed unemployed for more than a year)i had to give it away..Anyway everything is going right now and managed to get my self a small car(the micra k11 with 1.0litre goodness! lol )..I have loads of things hanging around due to the daihatsu i had (turbo,intercooler,blow-off valve ect.)and i'm consider a DIY light turbo,meaning i'm keeping stock internal's and combustion pressure..What i want to ask is are the stock injectors up to the task for pressure up 9-10 psi?If not are the cg1.3 injectors any bigger?If not again which will do the job without over-fuelling(sr20,cg1.4a,sr16)?Of course the ecu is going to be remapped what i'm looking is for a straight fit-bolt on if you prefer..
Also i would like to ask will the fuel pump be enough?Could i get away with bigger injectors and maybe a fuel pressure regulator?
Have everything else sorted out like water line feed,oil line feed,manifold ect..Sorry for the many questions at once guys..Thank's in advance..
There is a mass of information (all the answers to your questions and much more) on this site:) check threads like pollyp's blog, Solaris blog, stani's blog, my blog...
no
they're the same size as cg10
You could use ga16 but most use larger
nothing is bolt on when turboing a cg
it should be more than enough, I think only 2/3 people have swapped for a higher flow rate
iirc Rob did this with a fuel controller as well
I've answered as best as I could
Stani1029
Im using 370cc injectors and 80% of them is being used. I run 12psi daily theres just no way a 1.6 injector could handle that,as for buying fuel pressure regulators and fuel controllers youd be aswell getting a nistune board and do it properly
pollyp
there is a huge amount of variables to consider when ur thinking of boosting that much, pushing the engine and car beyond it's intended spec closer towards failure.
any performance modding project is about the balance of budget, timescale, resource, effort, reliability, safety, legislation/MOT.
but I'll use mine as an example. originally I got the turbo setup from a previous owner so most of the hard work was done but here's a list of everything that needed upgrading/change.
I run 10psi, 160bhp, 160ftlb, standard 1.3 internals (up to now), using it daily with occasional track days.
FUEL
98ron super unleaded
walbro 255lph pump (previous GTS-T pump couldn't keep up with 160bhp near the redline on trackdays)
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-36#post-482610
modded sr20de fuel rail & sr20 regulator (came with the turbo kit)
then upgraded to 370cc injectors from a 200sx
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-20#post-448174
EXHAUST
custom manifold (came with turbo kit)
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-45#post-503515
TURBO
T2/T25 hybrid
custom oil feed (from the oil gallery plug near exhaust manifold) & custom oil drain back to sump
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-23#post-453731
had to eventually rebuild the worn smoking turbo
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-39#post-486823
DRIVE TRAIN
200mm helix organic clutch on stock flywheel (to guarantee it'll handle the force & heat of 160ftlb on track days)
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-42#post-501040
Gripper LSD (to maintain traction with 160ftlb but that much torque was shattering the preload ring repeatedly for some reason but its under lifetime warranty)
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-50#post-509271
BRAKES
GTIR ad22v calipers (for high speed braking on track)
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-3#post-395713
black diamond grooved discs
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-53#post-514095
black diamond predator FT pads
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-53#post-515275
15" Rota Grid forged alloys with Toyo T1R (massive heavy brakes needed at least 15" wheels to fit. sticky toyos was a major increase in grip)
COOLING
thicker 26mm Nissen radiator for an automatic k11
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-44#post-502988
ELECTRONICS
Nistune daughter board (after fitting the turbo, was remapped on a dyno by Ed at fusion motorsports)
http://micra.org.uk/threads/pollymobiles-rebuild.35251/#post-381122
colder BKR6E NGK plugs
Innovate LC-1 / XD16 wideband kit
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-15#post-437898
DIY electronic WOT boost controller
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-45#post-503265
INTAKE
pod filter
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-21#post-449929
custom inlet/intercooler pipes
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-49#post-508426
Saab 9000 recirc BOV
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-11#post-421475
GTIR MAF
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-47#post-505220
disconnected TB coolant lines (keep TB cool, will need to remove the fast idle waxstat mechanism)
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-44#post-502488
DIY teflon inlet manifold spacer (keeps manifold cold)
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-50#post-510149
INSURANCE
increased premium, and with at least 12 mods, very few companies will insure it
solarice
INSURANCE
I love the silence you get at the other end as they guys/girls head fails to comprehend the list of items you've just given him lol.
My 1.6 injectors are ok at 7 psi, though i'm backing it up with higher fuel rail pressure. Depends which way you want to go about it really....there's lots of variables because everyone has built their cars their own way. :)
pollyp
I know, that's why I state at the beginning of any quote if they can support least 12 mods, most freak out.
then as I run down the list to the guy at adrian, sky etc, u can hear their tone sigh of boredom n lose the will to live lol :D excessive list yes but it's ... making sure :p
Many thank's for the replies!Guys all i'm looking for(for starter's) is to get turbocharged with a small budget and with small gains..(thinking small due to budget)I believe 8-10 psi is not much of a pressure and the engine can easily take it..I'm more concerned about optimal fuelling..Most likely i will be using a small turbo from a starlet(ct-9) with max boost up to 10psi-0.7bar(due to spring in the wastegate)..I know i could change a wastegate for one with a softer spring but there isn't much difference(pressure-wise)..
So bigger injector's(GA16) and a remap should be more than enough for this kind of pressure you say?
Last but not least...I read in a couple of thread's that the MAF sensor tend's to reach it's limit's no higher than 0.5 bar-7psi and
also that a MAF sensor from a s13-s14-200sx-Gti-r would be ok,so that's that...?
