Retepetsir
King of Subsonic
Arnold, you asked about this in the other thread
The best thing to do to begin with is get your system scoped, which basically means using an oscilloscope and a test tone to make sure that your system is setup to achieve maximum output without driving the amp/speakers into clip. A clipped signal (flattening of the peaks of the sine wave audio signal) can quite often result in toasted equipment :glance:.
Once that's done, you might want to find out the dB output that your setup can acheive. This is done with a special audio mic and measuring device, usually designed for in-car use.
The old standard (used in competitions) was the Audio Control 150 or 160, measuring to 150db or 160db respectively. The mic is attached to the windscreen on the passanger side of the car.
However, the new standard is the Termlab, which is more accurate, and actually measures slightly lower than the older mic's (by around 5-7db) but has greater accuracy. The Termlabs are around £500 to buy, which is expensive for most people, but a bargain for the spl competitors....
i.e. A 150db score on the old mic's would result in around a 145db score on the new mic's.
The current world record is something stupid like 177dB on the new mic's, which to put it mildly, is insane!
It's good fun measuring SPL (sound pressure level), but you need to remember that a lot of factors effect the final reading! From box tuning frequency, to sub choice, to frequency that is played for the reading, the power per sub, etc, etc.
The pro competitors tend to just 'burp' their subs with a single frequency for 3 seconds, to get the highest score possible.
However its much more fun to see what score can be acheived with music :devil:
If you want your car metered, I know that you can enter the free 'TALON' talkaudio compeition at the talkaudio T-meet's. For more info, checkout their forums at www.talkaudio.co.uk. It's also a great place for looking up answers to questions, and asking for advice.
Hope that kind of helps people!
