Anti roll bar clearance?!
When I had my car on the ramp the other day I noticed the anti roll bar is very close to the shell. Anybody else have the same? Could be the cause of the knocking noise.
OP
OP
Scott.c
Cars being too low can cause a knocking anti-roll bar but yours looks ok :/
I hit a pot hole at about 90 on a motorway the other day and I thought my wheel got ripped off it sounded horrible!!! Got a squeak from the passenger side from then, pretty sure it's the top mount.
h701micra
Deactivated Account
When does it squeak just generally?
When cornering, when hitting a bump?
skymera
Brutal Honesty
Check rear engine mount. Mine was loose and caused a loud squeak over bumps . 3 bolts.
Sent from my HTC One using Tapatalk
OP
OP
Scott.c
I'd agree with top mounts
Try wishbone bushes and anti roll bar bushes too
When I jacked it up to change the wheels over, I grabbed the strut and gave it a good wobble and there was a bit of movement so I'm going with top mounts.
