annoying rattle
evening lads
hope you can help
i have an annoying rattle when moving through the gears (1997 micra )
occurs when im accelerating - hard to explain - when i move into 2nd until im moving relatively fast there is a rattle - up a gear same thing hapnes till i speed up
any ideas coming from what sounds like the back of the car underneath ( heheh if that helps )
thanks in advance
jimbo :)
mmm, occuring slightly differently to what most people have posted about a rattle noise (my rattle only occurred at idle...) but i guess it could be the cat heatshield...they are always going so maybe worth a look under the car...
give some stuff a push around while youre there lol, just incase its somthing else. :D
erm
:s
when im accelearting in neutral??
or when im at a standstill ?
happens when im in neutral accelearating to a lesser degreee, doesnt happen whem im not acceleratinng
hope that helps
just meant if your sat with engine off and you put it into gear and wiggle gearstick around does it mke any noise?
