timmchugh1
Has anybody else come across the problem of the metal inserts that come with the panhard rod being too big? I fitted mine the other day and the larger one that goes on the axel was too bid for the stud.
Also when I fitted it there was a slight knock when I went over bumps, which has gradually got worse. I have checked everything is tight, but it is that under tension I cant get it to do it while its jacked up.
Any ideas?
Cheers Tim
Any ideas?
Cheers Tim
