773 Cams Duration and Lifts
He is the correct timing spec for the 773 rally cams.When ordering and new or reprofiled cams you should get this information from the cam grinders.
773 Rally cam Spec Nissan Micra from Humphris Oxford Ltd www.humphrisoxford.co.uk - Matt
Timing Data
..................................................................................................Duration...........V/L................V/C................F/L...........LATDC
Inlet..........Open 26 BTDC....Close 58 ABDC.............................................264.............9.09mm...........0.210mm........106..........1.70mm
Exhaust.....Openn 58 BBDC....Close 26 ATDC.............................................264.............9.04mm..........0.254mm........106...........1.65mm
Rocker Ratio = 1.00 : 1
Overlap = 52 Deg
Timing = Valve timing figures, measured in crank degrees
Duration = Total duration, measured in crank degrees at end of ramp
VL = Valve lift measure in mm
FL = Valve full lift measured in crank degrees ATDC inlet, BTDC exhaust.
LATDC = Valve lift at top dead centre measured in mm
