i have just got my k11 after 10 years of owning one-
i modify for performance and fuel economy only - i aint bothered about looks
Done Mods so far:
i took off the air box and pipes and stretched a vectra B 2L16v induction hose on it [keep the air flow on as it joins the 2 rubber hoses together-lay the pipe and cone to the o/s front-place the vacuum hose in where the vectras breather hose was and gaffa tape seal it
-stick a breather catch pot on the end of your breather hose and let it to the out side - i dont get any smoke or smell!
- i put a viper on the end of the vectra pipe-but a cheap cone will do
-advance dizzy timing [loosen 2studs and twist] - listen to the revs-paint previous setting to return to
-i eco-tek'd the servo pipe
-i will power boost it when i get a fuel rail plate
other mods to follow
-fit 10mm races leads i have left lying about
-heat resistant paint to all zorst pipes with heat wrap to manifold
-blank off EGR
-Headwork port spit and polish / rough out inlets / polish outlets / bevel inlets / lightly centre punch base of cylinder head for turbulance as with inlet ports
-Rework and rough out throttlebody
copy at your own risk m8- i have a traders insurance policy covering all modifications
but mine...shes drives and sounds like a motorbike lol
i like the idea of the 1.3 cams tho anyone done this for a 1.0L?
dont put a large bore exhaust on - you need the back pressure or it will be flat as a fart!
its a £250 throw away banger so not buying anything new for it
