160sr sparkplug changing guide
Cheers Daren, just watched it on my phone. That makes it look surprisingly simple. Only thing that puts me off is the guy at Nissan told me it needs a new manifold gasket when refitting. Mind you, service manual says not to use 3 of the bolts removed when changing a front damper but I suspect i'm going to any way :).
I suppose it makes sense to fit a new gasket, no mention of torque settings either but it does make it seem pretty straight forward.
That's alot of mauling around
I can't remember if I have done one of not but I'd imagine it's not that hard and I doubt very much you will need new gaskets but while it's off I guess you may as well swop them as there only cheap
6.5x55 you've got quite a list of jobs on your car building up lol
Just had a look in the manual and the torque settings are there and it does say replace the gasket:doh: 6.5x55 has to do it - just for adding the tutorial to his website!!
Ok, I'll pop into Nissan for one on Saturday and have a crack - how hard can it be? (Shortly followed by DOH :doh:!)
