13" alloys and lots of K10 parts.
boyracergt
Unfortunately the times come to sell one of my cars so the ten has to go before i sell it i need to clear out all the spares first. all parts marked with (*) came off the old engine in my 92 1.0 with 76k and where all working fine prior to removal. Due to lack of time all parts are offered collection only although might be able to do discount if your coming far. dont be afraid to ask.
1. Set of Fondmetal alloys. 13"x5.5J been told these where optional extras on k11s they have nissan stamped in the rim and are perfect centre bore and offset size. 3 wheels need refurbing due to corrosion and 2 tyres are below 1.6mm. have all 16 special tapered nuts and all 4 centre covers. paid 90 few months ago unused since then wanting £85
2. Standard 1.0 carb came off a car with 55k and bent valves so sold as untested one of the wires has come out the plug. £15
3. standard air box usual surface rust. £15
4. * standard alternator. good working order. the supressor on the back is broken but this never caused any problems. £25
5. Standard jack inc handle and wheel nut wrench. looks hardly used. £15
6. * Standard inlet setup inc carb and most pipes goodworking order. jets cleaned out
2k before removal. £35
7. * Starter motor and dizzy. both working before removal. dizzy is missing the wire but this is easy to fit. £25 Each
8. * standard suspension. no sign of leaking from shocks, no rear shocks. springs are ok but a fair amount of surface rust. front bump stops need replacing. £35
9. Door pockets. as fitted to higher spec models. came off a 5 door but should fit 3 door aswell. ones been badly sprayed black the others in standard grey. £10
10. open mouth grill. has been cut and fibreglassed just needs rubbing down fillering and spraying. £20
11. 5 door, door sill covers. fitted to higher spec models replaces the rubber strip that holds the carpet down. only have the front 2 £10
12. Rear anti-roll bar setup as fitted to the super s. includes arb nuts and bolts and the required square lower links. £35
13. Sunny ZX coupe side skirts and spats. these are pretty rare now. got these to go on the k10 as they are different to the norm. the skirts will require shortening by about half an inch to an inch (they are 3 peice so fairly easy to do) spats will require a fair amount of shortening/reshaping. comes with the required plastic/rubber gaskets except for one of the ones that fit the front section. £45 ono
14. Front drivers wing in red. paints badly faded but no rust. £25
15. rocker cover usual surface rust. £20
Visiting the midlands anytime soon? I'd be interested in the wheels but dont fancy slapping courier on top (Y)
