1.4 sport+ Coilpack Problem?
hey my wee mictq is idleing really poor up and down on the revs feels down on power when you put your foot down strugles to do 100mph and it uses a hell lot of fuel anyone think what it is?
Air filter blocked/blocked intake pipework/plugs need gapping/need new ht leads/inlet cam lobes worn
start from easiest to check and work way to most difficult.
If you can't pinpoi t it by checking, replace in order from cheapest to most expensive until problem is resolved.
It's coilpack enuo.
I had the same issue on mine, turned out to be a dodgy coilpack. Try the breakers, swap them over until it's all working as it should. If not that then it'll be the maf probably.
