1.2 k12 turbo
I'm thinking of cowboying a turbo kit for my car it's the 1.2 k12 sport in using an Astra 1.7 cdti turbo and intercooler but I'm a bit stuck for how to properly add an oil feed for it? Anyone have any advice? Thanks in advance
Problem I have is I have no way of mapping it in, it's basicly getting bolted on and the boost turned right down and tweaked from thereeverything else is stock
Does anyone have a help on where I could route the oil feed from?
Oil pressure switch take off on back of block? Fit a 'T', switch on one arm and feed to turbo on other? Not sure about the return feed back to the engine though...........
Was thinking that, unsure where to get a T junction from though, going to drop the pan and weld a connected on it for return
Something like THIS, though you would have to check the threads of the OEM pressure switch
edit:- Better still HERE as a full selection of different threads....
