I'm thinking of cowboying a turbo kit for my car it's the 1.2 k12 sport in using an Astra 1.7 cdti turbo and intercooler but I'm a bit stuck for how to properly add an oil feed for it? Anyone have any advice? Thanks in advance
Oil pressure switch take off on back of block? Fit a 'T', switch on one arm and feed to turbo on other? Not sure about the return feed back to the engine though...........Does anyone have a help on where I could route the oil feed from?
Was thinking that, unsure where to get a T junction from though, going to drop the pan and weld a connected on it for returnOil pressure switch take off on back of block? Fit a 'T', switch on one arm and feed to turbo on other? Not sure about the return feed back to the engine though...........
Something like THIS, though you would have to check the threads of the OEM pressure switchWas thinking that, unsure where to get a T junction from though, going to drop the pan and weld a connected on it for return
Your THIS and HERE aren't working budSomething like THIS, though you would have to check the threads of the OEM pressure switch
edit:- Better still HERE as a full selection of different threads....
That works cheers bud
