I'm thinking of cowboying a turbo kit for my car it's the 1.2 k12 sport in using an Astra 1.7 cdti turbo and intercooler but I'm a bit stuck for how to properly add an oil feed for it? Anyone have any advice? Thanks in advance
Problem I have is I have no way of mapping it in, it's basicly getting bolted on and the boost turned right down and tweaked from thereeverything else is stock
Oil pressure switch take off on back of block? Fit a 'T', switch on one arm and feed to turbo on other? Not sure about the return feed back to the engine though...........
Something like THIS, though you would have to check the threads of the OEM pressure switch
edit:- Better still HERE as a full selection of different threads....
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
