1.0l problem need any ADVICE please!!
so i went to my friends house today for 2 seconds went to start the car and nothing just turn over further looking into it i had no spark the car has ran fine never miss fired on me ! has any one had this problem or common faul i belived to it being a crank sensor?
Antony
it is more than likely that an earth cable has come off.....
but i suspenct that it may be the immobiliser is not turning the fuel pump on... when you put the key into ignition, before it turns the engine over, can you hear the pumps priming under the rear seats? if not, its the immobiliser
frank
yeah the dizzy and rotor arm is turning fine frank is there a fuel cut of swtich or anything that might cut out the spark ??
no, and the dizzy,s tend to fail when hot rather than suddenly go eh :eek:
you could try wiggling the big plug to the ecu maybe ? (mine would lose its spark unless i skewed it slightly) or try another dizzy ?
N
tried all that nothing =/ took aprat the dizzy etc.. to find the plug conector has been glued on at some point :( and some very dogy wireing has been done to the loom
