im planning on running 195/50/15s.
So basicly it wont make much of a diferance on either gearbox?
frank, the 1.0L gearbox to use with the 1.3 is it the facelift model with a speedo gear in it? if so what year and what numbers would be marked on the gearbox to determine to get that gearbox if i go to the breakers, im also planning to get a 1.3 slapped in my micra and do want a quick 0-60 from it using the gearbox mentioned.
J
good point J, i would guess that the sender/speedodrive is interchangeable maybe ?
and the numbers are near the cable support apparently (cant find mine tho )
