sr_steve Aug 5, 2009 #1 would a 1l gearbox make any difference and would it be a dirrect fitment? cheers
A Alienfish360 Awesome Dawson Aug 5, 2009 #2 You would need, rear engine mount, cg10 flywheel and clutch, and driveshafts. the cg10 gearbox is also weaker and the clutch is smaller.
A Alienfish360 Awesome Dawson Aug 5, 2009 #4 yeah, for my CG10 turbo I'm going to be using a CG13 box most likely.
frank Club Member Aug 5, 2009 #5 Alienfish360 said: You would need, rear engine mount, cg10 flywheel and clutch, and driveshafts. the cg10 gearbox is also weaker and the clutch is smaller. Click to expand... the post 98 1.0 g/box is a direct fit, and the post 2000 (14" wheel) 1.0 has the sought after 4.5 diff (handy if you,re running big wheels)
Robb Site Supporter Aug 5, 2009 #6 I should source one of those c/p 1.0 gearboxes methinks for when i get the clutch and fly done
frank Club Member Aug 5, 2009 #7 Robb said: I should source one of those c/p 1.0 gearboxes methinks for when i get the clutch and fly done Click to expand... i think you,ll find they are like rocking horse poo robb the yard with 6 or 8 late 1.0 k11,s where i go for my spares, shipped all the g/boxes to germany (£180 each) (ken had one tho iirc)
Stani1029 Club Member Aug 5, 2009 #8 you would need the linkage and stabilizer bar aswell as the rest of the stuff, its not worth it as youll lose the higher top speed
