Anyone ever tried these discs on a k11?
Ideally you'd want vented discs rather than drilled/grooved as that would give you the biggest benefit in an upgrade. Unfortunately you'd then need calipers to go with the vented discs as only the 1.6 Almera, 100NX, Primera, etc will fit their own calipers (practically a straight swap).
Not bad for the price though, but they would mainly be for looks...
As Rob says the standard ones do the job, having said that if you work the brakes very hard and suffer fade these discs might help.
I've just bought a pair of standard discs for £15.32, but I never drive hard these days.
Forgot about this thread lol, i still need to change the discs but ive got more life left in the pads after checking than i thought, for around £15 quid i will prob stick with normal ones too :)
Hi Rob,
I got some ADL blue print discs and pads, the pads look OE quality from Japan,
just £26.08 for the lot trade.
Pads are quite thin to start with so it makes sense to hang on until they really need changing, mine have a fair bit left on too.
