Creeking on Steering on K11
Hi All,
trying to work out what issue ive currently got which I feel could be something to do with the steering rack, when I turn right at low speed, it creeks and I don't know whether its a joint gone on the steering or what else it could be.
Thanks Tom.
possibly suspension strut or wheel alignment/bushings if it's only on one side, also possibly engine mounts?
Could be a few things
Had a look and found the CV joint on the left side has quite a lot of play laterally across to the gear box trying to find out how much play there should be there as I feel it might be that and the CV joint bearing
