EBB's throttle body spacer info/images?
Hi there I'm after some images or info ebb's throttle body that he made made up way back when as all the images are dead now and info is fairly had too find apart from what in can see on here and on his site any help would amazing thanking you all muchly
Sent from my U7 Plus using Tapatalk
Yer all I can find is people talking about it but no images don't wanna start making what I think it would be and just waste my time haha 3" is quite thick would that make the body protrude into bonnet?
I ended up going out on a whim and I bought a £2 nylon chopping board from asda last night. I decided too make 3 separate spacers there all a 1/4" think so I've used all 3 I've fitted them along with the a tb I've modded took her for a test run. Its defiantly going better but I'm waiting for the gasket sealer too cure off properly now its in place I'll be removing it all later so I'll take some pics and report back on my 1L power mission haha
Bit slow on the update but after some arguments with sealer I decided too heat the 3 separate sheets while I had them bolted together. (pictures will be build orderish)
So once I'd heated the boards and refitted I noticed the throttle response is much better I do have a slight bit of resistance too the pedal in the morning but once its given a small blip this is gone so I going to have too invest in a new throttle cable due too mine being old and quite stretched.
I did think about refitting a the auto kick down throttle hanger that I had used on another throttle body I modded as this made the cable sit further back and give me a lot of adjustment room but due too the new height of the tb I think I'll give it a miss.(last picture is of the other tb I modded with auto kick down hanger)
