Shwipers
Hello all,
So I've had that common issue with the wipers and have replaced the wiper linkages using a replacement set off eBay...should've done the trick, but I've noticed there's still some extra movement from the wipers and they catch the edge of the windscreen when v wet and in windy conditions. There's some play and they move together (a little) when I manually wiggle them up and down with my hands.
Has anybody else still had this lurking issue, and what could a solution be (other than forking out £250 on a new assembly from Nissan)?
This guy says to get the kit off ebay. He also shows how they move around and has couple tips for different options on this. You should take a few moments watch this not sure what method would be best though here.
