My Micra is misfiring.
- I've had a look at the condition of the spark plugs (1 year old) and they're fine.
- When I pull the HT leads off each spark plug in turn, the engine seems to behave the same way.
- My HT leads and dizzy cap are fairly new - I replaced both last December.
- The rotor arm is 2.5 years old - could it be that?
- I recently had a problem with the choke failing to open properly (solved by lubricating the choke linkages).
- I still have a problem with the choke stick open too long but that disappears after 5 minutes usage and the misfire is still present.
- I had a loose HT lead last year so possibly could have coked up a cylinder
Things I haven't checked (that I can think of):-
- coil
- dizzy itself
- rotor arm
All suggestions for what to check next appreciated!
Cheers,
Daniel
- coil
- dizzy itself
- rotor arm
Cheers,
Daniel
