I have a 94 nissan march. I guess the only difference is that one has 3drs and the other has 5drs. My question is, would a micra body kit fit my march? Would there be any modifications to the body kit for it to fit?
yeah the micra and march body shells are one and the same...apart from like you say 3 or 5 doors and differing trim parts. Depending on what kit youre after it may require modifcations (especially if its originally designed for another car) to either the kit or car...if its desgned for the micra/march then any alterations should be minor, but i'd always double check with the company that sells it just to be on the safe side.
as above micra and march are the same apart from diffrent trim and other small bits.....the kits are the same unless you have a 5-door micra or march the side skirts are diffrent... or if you have a saloon march (with a boot) the rear bumper will be diffrent.
