K10 and K11 Parts...will swap for money.
solarice
Right got a few bits that are taking up space, so they are looking for new owners. :D
K10 Stuff (will be updated as and if i find more stuff) -- all from a 1.0
1. Stock orange side repeaters (lenses only) -- As new : £1 + p&p
2. Carb and inlet manifold (carb has an idle issue, probably just needs rebuilding but never looked at it as i just replaced with a working unit) : £5 + p&p
3. Radiator fan and motor -- was working 100% when removed : £10 + p&p
5. Ash tray in brown -- slight wear : £1.50 + p&p
6. Lockset (NOT including ignition) -- three of the four have very neat faces, one is messed up slightly arround key hole -- I need to find the key for these. : £?? + p&p
7. Factory cigarette lighter -- some wear on element : £1 + p&p
8. Radiator Header/overflow tank and hoses : £10 + p&p
9. Ariel : £3.50 + p&p
10. Factory Air box -- slight surface rust on lid : £?? +p&p
11. Radiator Drain Plug : £1.50 + p&p
12. Fan controller thermostat (bolts into radiator), was working when last used so should be fine : £2 + p&p
13. Random Hoses -- Tell me which bit from the pics you want and we can work out prices. : £?? +p&p
14. Inlet manifold -- Bare : £?? +p&p
Instead of uploading new pics, if you check this old forsale thread you can see the pics there...these are the same items so whats in the pics is what you will receive, so long as its listed above. :)
http://www.micra.org.uk/threads/numerous-k10-parts-available.6309/
K11 Stuff (will be updated as and if i find more stuff) -- all from a 1.3
1. Early K11 Throttle body (removed from a 93 iirc) -- Tested and working : £35 delivered.
2. Early Type K11 front grill (my original grill) -- in white (has been repainted) and in stock condition : £10 + p&p
3. Early Type K11 front grill -- partially cut up, has a crack thats been glued...needs finishing : £?? + p&p
4. Cam cover -- needs a good clean inside and out. : £?? + p&p
5. Standard fuel pressure regulator. : £?? + p&p
6. Standard Inlet Manifold : £?? + p&p
7. Drivers and Passenger Wing Mirrors (black plastic, both have slight scratches iirc) and base plate trims (non adustable from inside of car) both are folding iirc : £6 each + p&p
8. Pre-facelift Boot number plate light (non handled) -- slight surface marks (so ideal for spraying) no lights or metal screws, but all mounts are intact. : £6 + p&p
9. Two inner CV Boots -- Brand new in box (need to find what i paid for them really) : £?? each + p&p
Open to offers on all items...so send me a pm. ;)
Any items that dont have pics i can provide them on request.
OP
OP
solarice
solarice
Forgot to include in the original post the following (and for some reason i cant edit / update it??) :
K11 Stock Springs Set of four : £?? p&p
K11 Stock Shockers -- Two rears and one Front : £?? +p&p
Both the above have done about 70k miles
Ive also got random stuff like an accelerator pedal, different cap for washer bottle, interior dash switches. Probably easier if i dig it all out and take one big picture. :)
OP
OP
solarice
solarice
OP
OP
solarice
solarice
Bit of a description of pic above (incase you havent looked at th epic ;)) : x2 brake fluid caps (one black, one blue) x3 washer bottle caps (two clear, one blue)
Also a bit of an update...seeing as i cant update the original post.
K11 rear springs, K11 stock grill, K11 inlet manifold and K11 wing mirrors (D & P) : SOLD.
Also just found :
1. Partially sanded super s door bump strips, think they're ok but have been knocking about in storage for a bit. Would need sanding, cleaning up and painting before fitting -- dunno if anyone would be interested. : £?? + p&p
2. Set of clear side repeaters (like the stock orange bubble / disc type -- 93 to 98 ) -- includes lens and loom (possibly also bulbs -- forgot to check o_O ). so its a 5 minute swap job. : £11 posted
Will update if i find anything else that might be of interest. :)
OP
OP
solarice
solarice
Just an update : The washer bottle caps are a different diameter than the micra filler neck. So dont fit the micras (unless anyone knows the later k11's had for deffo a smaller diameter filler)...apart from that no idea what they do fit either.
OP
OP
solarice
solarice
Small update :
K10 side repeaters, K10 aerial, K10 airbox, K10 cig lighter, K10 fan controller thermostat, K10 Rad drain plug -- SOLD
Anyone reading, remember im open to offers on everything listed.
OP
OP
solarice
solarice
Fuel and Boot release mech. Paint in very good condition, few light scratches...includes everything you need to fit and a petrol cap (as its attached to the door.).
Some modification may be needed to the internal sill or handle mech. Probably depends on car spec / model. :)
Me being an idiot i forgot the boot latch (as the eagle eyed people may have noticed from the pic)...i will get this collected on monday.
Not sure on paint code but its a metallic grey (can get code on monday aswell). Looking for £25 posted.
OP
OP
solarice
solarice
Now have all the bits you need to fit the petrol and boot release. As always open to offers. :)
Couldnt check the paint code, but not an issue if you plan on stickering or painting.
OP
OP
solarice
solarice
Tiny Update : 1 Inner CV Boot -- SOLD
Whats Left :
1. Early K11 Throttle body (removed from a 93 iirc) -- Tested and working : £30 delivered. PRICE DROPPED
9. One inner CV Boot -- Brand new in box (need to find what i paid for them really) : £8 delivered
10. K11 Clear Side Repeaters (Lens and Loom - no messing about with two or three pin keyways) : £11 delivered.
11. K11 Fuel and Boot Release (Full Kit) : £24 delivered. PRICE DROPPED (cant go lower im afraid)
12. K11 Super S Bump Strips (partially sanded) : £?? + p&p
13. K11 Front Springs £?? + p&p
14. K11 Front Stock Shock £?? + p&p
15. K11 Rear Stock Shockers (Pair) £?? + p&p
As always open to offers, so if you see something you want PM me and we can discuss.
OP
OP
solarice
solarice
Couple more bits :
1. Interior Head Beam adjuster switch (use as a replacement item) : £3 + p&p
2. Interior Blank with red led (alarm) : £1.50 + p&p
3. Interior Blank (dark? grey x 3) : 30p each + p&p
4. Interior Boot Light (bulb housing and lens, plus a bit of loom - would need an activation switch working out) : £2 + p&p
Items i can probably get (if theres interest) - LIMITED TIME :
1. Rear quarter popout windows : £30 + p&p
2. Super S / SR Rear Spoiler : £?? + p&p
PM Me to discuss the above or make offers on anything i've got listed.
Seb_
Give me some frogs.
Site Supporter
I would be interested in the flap only? 15£ postes?
Envoyé depuis mon MB860 avec Tapatalk
OP
OP
solarice
solarice
Sale fell through so Fuel / Boot release kit still available.
If you want anything make an offer. :)
Also have the chance for a few facelift rear spoilers (the little one that sits on the top) if anyone is interested PM me.
SirChris
Educated Bodger
Whats Left :
Any piston/rod assy?
Do you by any chance have a pillar trims with the small tweeter mesh in them? not fussed about the tweeters if you have them or not
OP
OP
solarice
solarice
K11 clear lens... those are for the repeaters on the front wings yea? not being silly?
Yeah like the ones on mine (same as the round orange stockies but clear), but also with the plug play loom. :)
Nah sorry mate, I dont really have any interior k11 trim bits. :)
