E34 RRT Apr 10, 2014 #1 hi do you have some distrubtors in uk thath can sell main and crank bearing in std dimensions, the nissan oem cost a lot!!
SirChris Educated Bodger Apr 10, 2014 #2 no, idea, never thought to buy non oem... I dont think many people would fix in most cases
frank Club Member Apr 10, 2014 #3 there are plenty of GA16 shell suppliers (for the big ends) and pollyp used MA ones for the mains iirc
frank Club Member Apr 10, 2014 #5 E34 RRT said: so ga16 for rod big end and ma10 to main?? Click to expand... i believe so, the MA anti-spin tangs were slightly different tho ? (covered in paul,s blog)
OP OP E34 RRT Apr 10, 2014 #6 does the qg13 fit? http://m.ebay.co.uk/itm/270916295294?cmd=VIDESC&gxo=true (im not in the garage now so i can messure)
pollyp Club Member Apr 10, 2014 #7 call some local garage/engine rebuild shops. that's where I got mine from.
frank Club Member Apr 10, 2014 #8 E34 RRT said: does the qg13 fit? http://m.ebay.co.uk/itm/270916295294?cmd=VIDESC&gxo=true (im not in the garage now so i can messure) Click to expand... hmm praps GA are too wide ? CG are 40mm x 15 and 45mm x 17 tho the b/e shells can slide 2mm sideways across the crank pins
Davegrout1 Apr 10, 2014 #10 E34 RRT said: hi do you have some distrubtors in uk thath can sell main and crank bearing in std dimensions, the nissan oem cost a lot!! Click to expand... got mine from nissan , seem to remember they weren't as expensive as i thought they would be :/
