Hey guys im kinda stuck on this one but which bit does nats read the chip from...reason being...
im just experimenting with a cga ecu n
1.
tried old key = dont work
2.
tried old key(means original barrel)
but the black plastic box thing under the barrel changed to new one (assumed this was the nats thing)
n holding new key next to it while turning old key = dont work
3.
swapping end of the old barrel (the black bit with the connectors)
old key
the new black box with new key agaist it = dont work
4.
the whole new barrel
new key
new black box = works
i would of thought so anyway on #4...
but what im trying to say/do is that i want to use old set of keys(cuz i got a couple as spare that my mum can use) but with the cga ecu (dont say swap locks to cga n use that key) as u can c ive swapped nearly every thing on the old barrel mech apart from actual barrel n it didnt work with old key. is it possible what i want to do? cuz pretend the black box was the nats n worked with old key but holding the cga chip to it. what i would of done is put the cga nats chip from new key in a little box type keyring n keep it hidden in car but use old keys as normal if u get me each time when wanting to start car just get the hidden cga chip hold again barrel n start car. it dont work tho help guys? (also dont say dont use the cga ecu reason being i got a cga but no time to put it in yet n when i do im gonna get same problem) getting extra keys made aint cheap at £50 a pop
1.
2.
3.
old key
4.
new key
